hwIViewControl Fit
Zooms into the dimensions of the curve in the plot.
hwIViewControl_handle Fit
HyperGraph Tcl Modify
This command zooms into or out of the graph based on the dimensions of the curve in the plot. It differs from ZoomIn or ZoomOut in that it zooms to the curve’s dimensions rather than a preset zoom. It also differs from CircleZoom in that it zooms to the curve’s dimensions rather than user-given dimensions.
hwi OpenStack;
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot AddCurve;
plot GetCurveHandle c1 1;
c1 GetVectorHandle x1 x;
x1 SetType Math;
x1 SetExpression (-6:6:1);
c1 GetVectorHandle y1 y;
y1 SetType Math;
y1 SetExpression sin(x);
w1 GetViewControlHandle vc;
vc Fit;
plot Draw;
Error
Returns success (0) or an error code.
Keywords
XY Plot
Tcl
Modify
