hwIXMLFile IsAttribute
Finds if the node or folder is an attribute.
hwIXMLFile_handle IsAttribute ident
Tcl Query
This command finds if the node or folder is an attribute. An attribute is a node, a name or value; NOT a folder of any kind. An attribute does not have levels below it. If the input is an attribute, true is returned. Otherwise, false is returned.
- ident
- The variable name (Templex statement) of the node or folder.
hwi GetSessionHandle sess;
sess GetXMLFileHandle XML "c:/Documents and Settings/user/My Documents/hwsettings.xml";
XML IsAttribute section.section.entry.5.value;
Error
Returns success (a true or false value) or an error code.
Keywords
Tcl
XML
Query
