hwIXMLFile IsValid
Finds if the file is an XML file.
hwIXMLFile_handle IsValid
Tcl Query
This command finds if the file chosen when the GetXMLFileHandle was called is an XML file. If the file is an XML file, true is returned. If it is not a valid XML file, false is returned.
hwi GetSessionHandle sess;
sess GetXMLFileHandle XML "c:/Documents and Settings/user/My Documents/hwsettings.xml";
XML IsValid;
Error
Returns success (true or false) or an error code.
Keywords
Tcl
XML
Query
