plt3DIPlot AddProjectionCurveGroup
Adds a new curve group to the HyperGraph 3D window.
pltIDIPlot_handle AddProjectionCurveGroup
Tcl Query
Projection curve groups hold multiple 3-D line curves used as visual references only. The most significant difference between curve groups and projection curve groups is that projection curve groups are not included in a "fit".
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName [myProjectName GetActivePage]
myPageName GetWindowHandle myWindowName [myPageName GetActiveWindow]
myWindowName GetClientHandle myPlotName
myPlotName AddProjectionCurveGroup
Success (0) or an error code.
