plt3DIPlot SetMeshLineThickness
Sets the display thickness of the mesh lines.
plt3DIPlot_handle SetMeshLineThickness thickness
Tcl Query
thickness
An integer from 1 to 10 with 10 being the thickest mesh line.
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName [myProjectName GetActivePage]
myPageName GetWindowHandle myWindowName [myPageName GetActiveWindow]
myWindowName GetClientHandle myPlotName
myPlotName SetMeshLineThickness 3
Success (0) or an error code.
