plt3DIPlot SetIncludeAxesInFit
Sets whether the axes box is kept visible by a fit operation.
plt3DIPlot_handle SetIncludeAxesInFit enabled
Tcl Query
In box axis mode, by default, the axes box is included in bounding box calculations, so as to keep it visibile when a fit operation occurs. Turning this flag off causes the plot to appear larger after a fit operation, but parts of the axes box may not be visible.
- enabled
- Keep axes visible, true or false.
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetSurfaceHandle mySurfaceName
myClientName SetIncludeAxesInFit false
myClientName DrawError
None.
