plt3DIPlot GetMetaData
Gets a named meta-data value previously associated with the plot.
plt3DIPlot_handle GetMetaData
Tcl Query
Metadata can be any string or string representation of a number. Returns a string (the meta-data value).
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName SetMetaData species narwhale
myClientName GetMetaData speciesErrors
Returns an empty string if the value is not defined.
