plt3DIPlot GetAxesScaleMethod
Returns the current axes scaling method.
plt3DIPlot_handle GetAxesScaleMethod
Tcl Query
Returns byviewport when the axes are stretched to maximize the window area.
byrange when the units have the same length along each axis.
none displays the axes as a cubical box.
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName [myProjectName GetActivePage]
myPageName GetWindowHandle myWindowName [myPageName GetActiveWindow]
myWindowName GetClientHandle myPlotName
myPlotName GetAxesScaleMethod
None.
