plt3DIPlot PasteBarChart
Pastes the bar chart curve from the internal clipboard.
plt3DIPlot_handle PasteBarChart index
Tcl Query
index
The location to insert the bar chart curve in the number of curves in the current HyperGraph 3D window.
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName [myProjectName GetActivePage]
myPageName GetWindowHandle myWindowName [myPageName GetActiveWindow]
myWindowName GetClientHandle myPlotName
myPlotName AddBarChart
myPlotName GetBarChartHandle myBarChartName 1
myPlotName CopyBarChart 1
myPlotName PasteBarChart 1
Success (0) or an error code.
