pltIBuildPlotsCtrl Class
Takes information from a model and translates it to be graphed in the Build Plots panel.
pltIBuildPlotsCtrl_handle AddRequestLocator rx_pool, rx_binding, rx_layer, id
Tcl Modify
This command takes information from a model and translates it to be graphed in the Build Plots panel.
rx_pool
The pool (specific group of information) that you want to get information from. You can call the GetPoolTypeList and GetPoolList commands to find the types of pools available for the file chosen.
rx_binding
The request type that you want to use.
“Nodes”
“Elements”
“Surface”
“Volume”
“Part”
“Assembly”
“Set”
“Model”
“System”
rx_layer
The layer of the model that you want to make a request locator of. To find the list of layers, call the GetLayerList command. If there are no layers, you must input an empty string “”.
id
The ID of the specific request that you want to make a request locator of. (ex: 293).
hwi GetSessionHandle sess;
sess GetClientManagerHandle mgr plot;
mgr GetBuildPlotsCtrlHandle build;
build SelectDataFile "c:/demos/mv_hv_hg/HyperView Stuff/d3plotag" true
build AddRequestLocator Node "Nodes" "" 246;
Keywords
Tcl
Build Plots
Modify
Create
