pltIBuildPlotsCtrl SelectYComponent
Sets the value(s) for the Y component.
pltIBuildPlotsCtrl_handle SelectYComponent values
Tcl Modify
This command sets the Y component.
Note: In order for the Y component to be set, the Y request and the Y type must be set before. If the Y component does not have any components in its list of components, this function would be unable to select a component. To find the list of components, call the GetComponentList command.
values
The input for the values variable is a list. The list must consist of the components that you want to use within curly braces, { }. Each string representing a component must also be within “ “ if there are any spaces in the string. Example: {“LOWER TORSO” “SHOULDER BELT”}. If you do not want a Y component to be set, empty {} must be inputted.
hwi GetSessionHandle sess;
sess GetClientManagerHandle mgr plot;
mgr GetBuildPlotsCtrlHandle build;
build SelectYComponent {" Resultant Force (N)" "Elastic Force (N)"};
Keywords
Tcl
Build Plots
Modify
