pltIBuildPlotsCtrl SetXDatatype
Sets the value for the X data type.
pltIBuildPlotsCtrl_handle SetXDatatype dtype
Tcl Modify
This command sets the value for the X data type variable from within the X data type list.
Note: The command GeneratePlot must be called after to draw the plot with these changes.
dtype
A string with the value of the X data type that you want.
hwi GetSessionHandle sess;
sess GetClientManagerHandle mgr plot;
mgr GetBuildPlotsCtrlHandle build;
build SetXDatatype "Time";
Keywords
Tcl
Build Plots
Modify
