pltIBuildPlotsCtrl GeneratePlots
Draws the plots that are set in BuildPlots.
pltIBuildPlotsCtrl_handle GeneratePlots
Tcl
This command draws the plots that are set in BuildPlots.
hwi GetSessionHandle sess;
sess GetClientManagerHandle mgr plot;
mgr GetBuildPlotsCtrlHandle build;
build SetLegend false;
build GeneratePlots;
Keywords
Tcl
Build Plots
Create
