pltICurve AddPoint
Adds a new XY data point to a curve.
pltICurve_handle AddPoint x, y, sort_axis
Tcl Query
If the X and Y vector types are File or Math, the vector type is changed to Values.
x
The X value of the new point.
y
The Y value of the new point.
sort_axis
Sorts by the x-axis ("x"), y-axis ("y") or none (blank, "").
Examples
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName [myProjectName GetActivePage]
myPageName GetWindowHandle myWindowName [myPageName GetActiveWindow]
myWindowName GetClientHandle myPlotName
myPlotName GetCurveHandle myCurveName 1
myCurveName AddPoint 0.001 500 1
Returns success or an error code.
