pltICurve GetEditHandle
Gets a handle to the pltIEdit interface for the specified edit (for example, cut, trim, bridge).
pltICurve_handle GetEditHandle iEdit, idx
Tcl Query
This method creates an interface and copies the pointer to it into this value. The caller is responsible for deleting it.
- iEdit
- A reference to a pltIEdit pointer.
- idx
- The index of the edit to which an interface is desired. Must be positive.
Returns success or an error code.
