pltICurve GetHighlighted
Gets the highlight state of the curve.
pltICurve_handle GetHighlighted
Tcl Query
Returns the following:
True
If the curve is highlighted.
False
If the curve is not highlighted.
GetSessionHandle mySessionName
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName [myProjectName GetActivePage]
myPageName GetWindowHandle myWindowName [myPageName GetActiveWindow]
myWindowName GetClientHandle myPlotName
myPlotName GetCurveHandle myCurveName 1
myCurveName GetHighlighted
None.
