pltICurve Hide
Applies a hide edit to the curve.
pltICurve_handle Hide from_val, to_val, orientation, interpolate
Tcl Modify
This method only applies the edit. Call the Recalculate method on the parent plot object to update the data.
from_val
The minimum value of the range to be hidden.
to_val
The maximum value of the range to be hidden.
orientation
The orientation of the edit.
horizontal
vertical
interpolate
True
Create new data points at from_val and to_val (using linear interpolation) if they are not already there.
False
Do not create new data points at from_val and to_val.
Returns success or an error code.
