pltIPlotManager GetExportCtrlHandle
Gets the export control handle.
pltIPlotManager_handle GetExportCtrlHandle iExp
Tcl Query
This command gets the export control handle. With the export control handle, you can modify the aspects of the export, including format, the file name, and the source. You can also export files with the export control handle.
iExp
The name that you want to call the export control handle.
hwi GetSessionHandle sess;
sess GetClientManagerHandle pm Plot;
pm GetExportCtrlHandle exp;
Keywords
Tcl
Export
Query
