pltIPlotManager SetUseEvenCycles
Sets the state of the Use Even Cycles option.
pltIPlotManager_handle SetUseEvenCycles state
Tcl Modify
This command sets if Use Even Cycles is on or off. If on, Use Even Cycles makes even cycles when fitting the log axes.
- state
- A true or false value.
- True
- When you want Use Even Cycles to be on.
- false
- When you want the option to be off.
hwi GetSessionHandle sess;
sess GetClientManagerHandle pm Plot;
pm SetUseEvenCycles true;
Keywords
Tcl
Modify
