pltIPlotManager UndoMacro
Undoes a macro.
pltIPlotManager_handle UndoMacro
Tcl Modify
This command “undoes” the macro after it has plotted a curve. To “undo” means to cancel or reverse the last command executed. This means that the macro that was plotted is removed from the plot (but the macro command is still available).
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
sess GetClientManagerHandle pm Plot;
pm UndoMacro;
plot Draw;
Keywords
Tcl
Macro
Modify
