pltIPlotManager SetPreloadMaximum
Sets the preload maximum file size for post-processing a large number of pedestrian result files.
pltIPlotManager_handle SetPreloadMaximum size
Tcl Modify
- size
- The file size in gigabytes. Specifying a size of zero disables this command. Smaller values sacrifice performance for memory and larger values sacrifice memory for performance. Files smaller than the specified size will be loaded into memory entirely.
hwi GetSessionHandle ses
ses GetClientManagerHandle plotClientMngr plot
plotClientMngr SetPreloadMaximum 0.5Errors
Keywords
Tcl
Macro
Modify
Create
