pltIVector AddDataAttribute
Attaches a data attribute to the metadata of the datasource (vector).
pltIVector_handle AddDataAttributesvarname, (value)
Tcl Modify
This command attaches a data attribute to the datasource (vector).
- varname
- Name of the data attribute.
- value (Optional)
- Specifies the value of the data attribute.
#Precondition : A curve must be available on the plot client window.
hwi GetActiveClientHandle cl;#Must be a plot client.
cl GetCurveHandle crv 1;#Get the handle of the curve at index 1.
crv GetVectorHandle yvec y;#Possible options are x or y or u or v
yvec AddDataAttributes HWTest "1"
(will attach a data attribute named "HWTest" and a value of "1" to the vector)
None.
Keywords
Tcl
Data Attribute
MetaData
Vector
Query
