pltIVector Freeze
Removes the dependency of this datasource (vector) from other datasources (vectors).
pltIVector_handle Freeze
Tcl Modify
This command removes the dependency of one datasource (vector) over others and copies the value if there is a dependency on other datasources (vectors). In other words, it makes the datasource (vector) independent of other datasources (vectors).
#Precondition : A curve must be available on the plot client window.
hwi GetActiveClientHandle cl;#Must be a plot client.
cl GetCurveHandle crv 1;#Get the handle of the curve at index 1.
crv GetVectorHandle yvec y;#Possible options are x or y or u or v
yvec Freeze
0 is returned on success or an error code is returned on failure.
Keywords
Tcl
Freeze
DataSource
Vector
Query
