pltIVector GetSubcase
Gets the subcase for the vector.
pltIVector_handle GetSubcase
Tcl Query
This method is only valid for file vectors.
Values for subcase depend on the particular data file associated with the vector.
Returns the subcase used by the vector. This is an integer value.
MyCurve GetVectorHandle x myX
MyX GetSubcaseErrors
3 = HW_InvalidHandle - The handle used to invoke the method is no longer valid.
