pltIVector SetFilename
Sets the filename of the data file referenced by the vector.
pltIVector_handle SetFilename filename
Tcl Query
This method is only valid for file vectors.
filename
The name of the data file to be referenced by the vector.
This method only changes the filename.
Call the Recalculate method on the parent plot object to update the data.
Success or an error code.
