Meshing and Elements
Meshing
Models are typically meshed automatically, but individual elements can also be modified manually to improve element quality in problem areas.
Meshing is organized by the type of mesh operation involved.
Elements
Elements are FE idealizations for a portion of a physical part.
Every element must be organized into one component, and therefore are mutually exclusive to a component.
