display |
Show/Hide |
global |
Deprecated |
HyperStudy |
Design Explorer |
options |
colors |
Preferences |
options |
geometry |
Preferences |
options |
graphics |
Preferences |
options |
graphics files |
Screen Capture |
options |
menu config |
Deprecated |
options |
mesh |
Preferences |
options |
page names |
Deprecated |
plotwindow |
Chart Manager |
spherical clipping |
Section
Cut |
transparent |
Geometry and Mesh Visualization; Browser |
trueview |
True View |
view |
Views; View Cube |
vis |
Geometry and Mesh Visualization |
| 1D |
admas |
create |
Browser/Entity Editor |
| 1D |
admas |
update |
| 1D |
bars |
bar2 |
Acoustics; Bars; Contacts; Generals; Plots; Rods; Shells;
Springs; Surfaces; Thermals |
| 1D |
bars |
bar3 |
Beams; Thermals |
| 1D |
bars |
update |
| 1D |
gaps |
create |
Gaps |
| 1D |
gaps |
update |
| 1D |
HyperBeam |
edit section |
Browser/Entity Editor; Sketcher |
| 1D |
HyperBeam |
generic section |
| 1D |
HyperBeam |
section utils |
| 1D |
HyperBeam |
shell section |
Shell Section |
| 1D |
HyperBeam |
solid section |
Solid Section |
| 1D |
HyperBeam |
standard section |
| 1D |
joints |
create |
Joints |
| 1D |
joints |
update |
| 1D |
line mesh |
Line Mesh |
| 1D |
linear 1d |
Acoustics, Axysymmetrics; Beams; Bonds; Contacts; Electrics;
Gaps; Gaskets; Generals; Joints; Links; Masses; Plots; Rods; Seat Belts;
Shells; Springs; Surfaces; Thermals |
| 1D |
markers |
| 1D |
masses |
create |
Acoustics; Bonds; Contacts; Gaps; Masses; SPH; Springs |
| 1D |
masses |
update |
| 1D |
rbe3 |
create |
RBE3s |
| 1D |
rbe3 |
update |
| 1D |
rigids |
combine |
Combine Rigids |
| 1D |
rigids |
create |
Rigids |
| 1D |
rigids |
update |
| 1D |
rods |
create |
Acoustics; Bonds; Electrics; Gaskets; Generals; Joints; Links; Rods; Seat Belts;
Thermals |
| 1D |
rods |
update |
Brower/Entity Editor |
| 1D |
sph |
SPH |
| 1D |
spotweld |
switch nodes |
Deprecated |
| 1D |
spotweld |
using elems |
Connectors |
| 1D |
spotweld |
using geom |
Deprecated |
| 1D |
spotweld |
using nodes |
Connectors |
| 1D |
springs |
create |
Masses; Springs; Thermals |
| 1D |
springs |
spring3 |
| 1D |
springs |
spring4 |
Springs |
| 1D |
springs |
update |
| 1D; 2D; 3D |
config edit |
Configure Elements |
| 1D; 2D; 3D |
detach |
detach |
Boolean/Detach |
| 1D; 2D; 3D |
detach |
detach from |
Boolean/Detach |
| 1D; 2D; 3D |
detach |
detach from wall |
Boolean/Detach |
| 1D; 2D; 3D |
edit element |
combine |
Edit Elements → Combine |
| 1D; 2D; 3D |
edit element |
create |
Edit Elements → Create |
| 1D; 2D; 3D |
edit element |
split |
Edit Elements → Split |
| 1D; 2D; 3D |
elem types |
Configure Elements; Preferences |
| 1D; 2D; 3D |
ET Types |
| 1D; 2D; 3D |
order change |
change to 1st |
| 1D; 2D; 3D |
order change |
change to 2nd |
| 1D; 2D; 3D |
replace |
Edit Elements →Replace |
| 1D; 2D; 3D |
split |
hex/quad elements |
Split |
| 1D; 2D; 3D |
split |
plate elements |
Split |
| 1D; 2D; 3D |
split |
refine elements |
Refine; Rebuild |
| 1D; 2D; 3D |
split |
solid elements |
Split |
| 2D |
acoustic mesh |
Acoustic Cavity |
| 2D |
automesh |
batchmesh |
BatchMesher |
| 2D |
automesh |
edge deviation |
General 2D Mesh |
| 2D |
automesh |
QI optimize |
General 2D Mesh |
| 2D |
automesh |
rigid body mesh |
Rigid Body Mesh |
| 2D |
automesh |
size and bias |
General 2D Mesh |
| 2D |
automesh |
surface deviation |
General 2D Mesh; CFD 2D
Mesh |
| 2D |
composites |
element normals |
Normals |
| 2D |
composites |
material orientation |
Orientation Tool |
| 2D |
composites |
ply directions |
Absorb to ply-based model (short term); Engineering
Properties |
| 2D |
cones |
full cone |
Deprecated |
| 2D |
cones |
user controlled |
Deprecated |
| 2D |
elem cleanup |
Auto Quality |
| 2D |
HyperLaminate |
Composite Browser |
| 2D |
mesh edit |
extend |
Imprint |
| 2D |
mesh edit |
imprint |
Imprint |
| 2D |
midmesh |
create |
Midmesh → Automatic |
| 2D |
midmesh |
edit edge |
Midmesh → Create Midedge; Edit Topology; Align |
| 2D |
midmesh |
edit face |
Midmesh → Repair/Fill; Align |
| 2D |
planes |
square |
Rectangle |
| 2D |
planes |
trimmed |
Surfaces → Patch |
| 2D |
quality index |
combine tria element |
| 2D |
quality index |
drag tria element |
Edit Elements → Move |
| 2D |
quality index |
element optimize |
| 2D |
quality index |
modify hole & washer |
| 2D |
quality index |
node optimize |
| 2D |
quality index |
patching |
Edit Elements |
| 2D |
quality index |
place node |
| 2D |
quality index |
smooth |
Edit Elements → Smooth |
| 2D |
quality index |
split quad element |
| 2D |
quality index |
split/collapse edge |
| 2D |
quality index |
swap edge |
| 2D |
rebuild mesh |
Rebuild |
| 2D |
ruled |
Surfaces → Ruled |
| 2D |
shrink wrap |
Shrink Wrap |
| 2D |
skin |
Surfaces → Skin |
| 2D |
spheres |
four points |
Solids → Sphere |
| 2D |
spheres |
full sphere |
Solids → Sphere |
| 2D |
spheres |
user controlled |
Deprecated |
| 2D |
spline |
Surfaces → Patch |
| 2D |
torus |
full torus |
Deprecated |
| 2D |
torus |
three points |
Deprecated |
| 2D |
torus |
user controlled |
Deprecated |
| 2D; 3D |
drag |
drag elems |
Hex |
| 2D; 3D |
drag |
drag geoms |
Extrude |
| 2D; 3D |
elem offset |
shell layers |
Offset |
| 2D; 3D |
elem offset |
shell offset |
Offset |
| 2D; 3D |
elem offset |
solid layers |
Offset |
| 2D; 3D |
elem offset |
thicken shells |
Offset |
| 2D; 3D |
elem offset |
thin solids |
Thin Solids |
| 2D; 3D |
line drag |
drag elems |
Hex |
| 2D; 3D |
line drag |
drag geoms |
Extrude |
| 2D; 3D |
smooth |
plates |
Edit Elements/Smooth |
| 2D; 3D |
smooth |
solids |
Solid Mesh Optimization |
| 2D; 3D |
spin |
spin elems |
Revolve |
| 2D; 3D |
spin |
spin geoms |
Revolve |
| 3D |
CFD tetramesh |
2D parameters |
HyperMesh CFD |
| 3D |
CFD tetramesh |
BL parameters |
Mesh Controls |
| 3D |
CFD tetramesh |
boundary selection |
Mesh Controls |
| 3D |
CFD tetramesh |
refinement box |
Mesh Controls |
| 3D |
CFD tetramesh |
tetramesh parameters |
Mesh Controls |
| 3D |
linear solid |
Hex |
| 3D |
solid map |
ends only |
Hex |
| 3D |
solid map |
general |
Hex |
| 3D |
solid map |
line drag |
Hex |
| 3D |
solid map |
linear solid |
Hex |
| 3D |
solid map |
multi solids |
Map |
| 3D |
solid map |
one volume |
Map |
| 3D |
solid map |
thin solids |
Thin Solids |
| 3D |
solid mesh |
Deprecated |
| 3D |
tetramesh |
refinement box |
Tet |
| 3D |
tetramesh |
tetra mesh |
Tet |
| 3D |
tetramesh |
tetra remesh |
Tet |
| 3D |
tetramesh |
Tet |
| 3D |
tetramesh |
volume tetra |
Tet |
| 2D |
accels |
create |
Accelerations |
| Analysis |
accels |
update |
| Analysis |
ALE setup |
add/update |
| Analysis |
ALE setup |
create |
| Analysis |
blocks |
create |
| Analysis |
blocks |
review |
| Analysis |
blocks |
update |
| Analysis |
bodies |
create |
| Analysis |
bodies |
parameters |
| Analysis |
bodies |
update |
| Analysis |
constraints |
create |
Constraints |
| Analysis |
constraints |
update |
| Analysis |
contactsurfs |
adjust normals |
| Analysis |
contactsurfs |
elems |
| Analysis |
contactsurfs |
faces |
| Analysis |
contactsurfs |
remove elems |
| Analysis |
control cards |
| Analysis |
control vol |
airbag |
| Analysis |
entity sets |
| Analysis |
equations |
create |
MPC |
| Analysis |
equations |
update |
| Analysis |
flux |
create |
Fluxes |
| Analysis |
flux |
update |
| Analysis |
forces |
create |
Forces |
| Analysis |
forces |
update |
| Analysis |
group misc |
add |
| Analysis |
group misc |
card |
| Analysis |
group misc |
create |
| Analysis |
group misc |
geom |
| Analysis |
group misc |
motion |
| Analysis |
group misc |
update |
| Analysis |
interfaces |
add |
| Analysis |
interfaces |
card image |
| Analysis |
interfaces |
create |
| Analysis |
interfaces |
update |
| Analysis |
load on geom |
Engineering Entities |
| Analysis |
load steps |
| Analysis |
load types |
Load Types; Preferences |
| Analysis |
loadsteps |
| Analysis |
moments |
create |
Moments |
| Analysis |
moments |
update |
| Analysis |
nsm |
create |
| Analysis |
nsm |
update |
| Analysis |
optimization |
Optimization Ribbon |
| Analysis |
OptiStruct |
Run OptiStruct Solver |
| Analysis |
output block |
| Analysis |
preserve node |
| Analysis |
pressures |
create |
Pressures |
| Analysis |
pressures |
update |
| Analysis |
Radioss |
Run Radioss Solver |
| Analysis |
rigid walls |
add |
| Analysis |
rigid walls |
card |
| Analysis |
rigid walls |
create |
| Analysis |
rigid walls |
geom |
| Analysis |
rigid walls |
motion |
| Analysis |
rigid walls |
update |
| Analysis |
sensor |
| Analysis |
set segments |
adjust normals |
| Analysis |
set segments |
elems |
| Analysis |
set segments |
remove elems |
| Analysis |
set segments |
solid faces |
| Analysis |
solver |
Deprecated |
| Analysis |
super elems |
Super Elements |
| Analysis |
systems |
assign |
Assign Systems |
| Analysis |
systems |
create by axis direction |
Systems |
| Analysis |
systems |
create by node reference |
Systems |
| Analysis |
systems |
Orientation Tool |
| Analysis |
temperatures |
create |
Temperatures |
| Analysis |
temperatures |
update |
| Analysis |
vectors |
create |
Vectors |
| Analysis |
vectors |
update |
| Analysis |
velocities |
create |
Velocities |
| Analysis |
velocities |
update |
| Connectors |
add links |
| Connectors |
apply mass |
Apply Mass |
| Connectors |
area |
area |
Area |
| Connectors |
area |
create |
Area |
| Connectors |
area |
edit |
Area |
| Connectors |
area |
realize |
Area |
| Connectors |
bolt |
bolt |
Fastener |
| Connectors |
bolt |
create |
Fastener |
| Connectors |
bolt |
edit |
Fastener |
| Connectors |
bolt |
realize |
Fastener |
| Connectors |
compare |
Connector Comparison |
| Connectors |
connector options |
apply mass options |
Connector Controls/Preferences |
| Connectors |
connector options |
area options |
| Connectors |
connector options |
bolt options |
| Connectors |
connector options |
fe config |
| Connectors |
connector options |
general options |
| Connectors |
connector options |
seam options |
| Connectors |
connector options |
spot options |
| Connectors |
fe absorb |
Absorb |
| Connectors |
quality |
1D elems |
Generic Element
Checks |
| Connectors |
quality |
3D elems |
Generic Element
Checks |
| Connectors |
quality |
connectors |
Connector Quality Check |
| Connectors |
quality |
projection check |
| Connectors |
seam |
create |
Line |
| Connectors |
seam |
edit |
Line |
| Connectors |
seam |
partition |
Line |
| Connectors |
seam |
realize |
Line |
| Connectors |
seam |
seam |
Line |
| Connectors |
spot |
create |
Point |
| Connectors |
spot |
edit |
Point |
| Connectors |
spot |
realize |
Point |
| Connectors |
spot |
spot |
Point |
| Connectors |
unrealize |
Browser; Idle |
| Geom |
align node |
Align/Lines |
| Geom |
autocleanup |
Defeature/Batch |
| Geom |
circles |
center & radius |
Shapes; Sketch/Circles |
| Geom |
circles |
find center |
Create Points/Nodes (using
snaps) |
| Geom |
circles |
points & vector |
| Geom |
circles |
three points |
| Geom |
defeature |
duplicates |
Surface Repair/Duplicates |
| Geom |
defeature |
edge fillets |
Defeature/Cuts |
| Geom |
defeature |
pinholes |
Defeature/Holes |
| Geom |
defeature |
surf fillets |
Defeature/Fillets |
| Geom |
defeature |
symmetry |
Find Symmetry |
| Geom |
dimensioning |
| Geom |
distance |
three nodes |
Measure |
| Geom |
distance |
three points |
Measure |
| Geom |
distance |
two nodes |
Measure |
| Geom |
distance |
two points |
Measure |
| Geom |
edge edit |
(un)suppress |
Stitch |
| Geom |
edge edit |
by feature |
Batch/Stitch |
| Geom |
edge edit |
edge fillets |
Defeature/Fillets |
| Geom |
edge edit |
equivalence |
Stitch |
| Geom |
edge edit |
replace |
Stitch |
| Geom |
edge edit |
toggle |
Stitch |
| Geom |
edge edit |
unsplit |
Unsplit |
| Geom |
fillets |
Fillets |
| Geom |
length |
Measure |
| Geom |
line edit |
combine |
Lines/Combine |
| Geom |
line edit |
extend line |
Lines/Extend |
| Geom |
line edit |
smooth line |
Lines/Polylines; Lines/Combine |
| Geom |
line edit |
split at joint |
Split/Interactive; Snaps |
| Geom |
line edit |
split at line |
Split/Lines |
| Geom |
line edit |
split at plane |
Split/Planes |
| Geom |
line edit |
split at point |
| Geom |
lines |
arc center and radius |
Sketch/Arcs |
| Geom |
lines |
arc nodes and vector |
Sketch/Arcs |
| Geom |
lines |
arc three nodes |
Sketch/Arcs |
| Geom |
lines |
circle center and radius |
Shapes; Sketch/Arcs |
| Geom |
lines |
circle nodes and vector |
| Geom |
lines |
circle three nodes |
| Geom |
lines |
conic |
Lines/Polylines; Sketch |
| Geom |
lines |
controlled nodes |
Lines |
| Geom |
lines |
drag along vector |
Lines |
| Geom |
lines |
extract edge |
Idle |
| Geom |
lines |
extract parametric |
Lines |
| Geom |
lines |
features |
Feature Edges |
| Geom |
lines |
fillet |
Fillets |
| Geom |
lines |
intersect |
Lines (with
snaps) |
| Geom |
lines |
linear nodes |
Lines/Polylines |
| Geom |
lines |
manifold |
Lines (with
snaps) |
| Geom |
lines |
midline |
Midlines |
| Geom |
lines |
normal 2D on plane |
Lines |
| Geom |
lines |
normal from geometry |
Lines; Snaps |
| Geom |
lines |
normal to geometry |
Lines (with
snaps) |
| Geom |
lines |
offset |
Offset |
| Geom |
lines |
smooth nodes |
Lines |
| Geom |
lines |
standard nodes |
Lines |
| Geom |
lines |
tangent |
Lines (with
snaps) |
| Geom |
lines |
xyz |
Lines |
| Geom |
midsurface |
assign target |
Deprecated |
| Geom |
midsurface |
auto extraction |
Midsurface/Automatic |
| Geom |
midsurface |
edit base surfaces |
Midsurface/Base Surfaces |
| Geom |
midsurface |
edit collapsed lines |
Deprecated |
| Geom |
midsurface |
edit plates |
Midsurface/Edit Plates |
| Geom |
midsurface |
extraction options |
Midsurfaces/Automatic |
| Geom |
midsurface |
imprint |
Midsurfaces/Pocket Imprint |
| Geom |
midsurface |
message options |
Deprecated |
| Geom |
midsurface |
review thickness |
Deprecated |
| Geom |
midsurface |
sort |
Deprecated |
| Geom |
midsurface |
surface pair |
| Geom |
node edit |
align node |
Align/Lines |
| Geom |
node edit |
associate |
Edit Elements/Associate |
| Geom |
node edit |
move node |
Move |
| Geom |
node edit |
place node |
snaps) |
| Geom |
node edit |
remap |
Align/Lines |
| Geom |
nodes |
arc center |
snaps) |
| Geom |
nodes |
extract on line |
Extract Points/Nodes |
| Geom |
nodes |
| Geom |
nodes |
interpolate nodes |
Create Points/Nodes |
| Geom |
nodes |
interpolate on line |
| Geom |
nodes |
interpolate on surface |
| Geom |
nodes |
intersect |
Snaps |
| Geom |
nodes |
on geometry |
Snaps |
| Geom |
nodes |
xyz |
| Geom |
point edit |
add |
Split/Interactive; Split/Parametric |
| Geom |
point edit |
project |
Imprint |
| Geom |
point edit |
release |
Stitch |
| Geom |
point edit |
replace |
Stitch |
| Geom |
point edit |
suppress |
Split/Interactive |
| Geom |
points |
arc center |
snaps) |
| Geom |
points |
| Geom |
points |
intersect |
| Geom |
points |
xyz |
| Geom |
quick edit |
add point on line |
Split/Parametric |
| Geom |
quick edit |
add/remove point |
Split/Interactive |
| Geom |
quick edit |
adjust/set density |
Edit Elements/Density |
| Geom |
quick edit |
delete surf |
Surfaces/Patch; Browser; Idle; Delete key |
| Geom |
quick edit |
filler surf |
Surfaces/Patch |
| Geom |
quick edit |
project point |
Imprint |
| Geom |
quick edit |
release point |
Stitch |
| Geom |
quick edit |
replace point |
Stitch |
| Geom |
quick edit |
split surf-line |
Split/Interactive with perpendicular snap |
| Geom |
quick edit |
split surf-node |
Split/Interactive |
| Geom |
quick edit |
toggle edge |
Stitch |
| Geom |
quick edit |
trim-intersect |
Defeature/Cuts |
| Geom |
quick edit |
unsplit surf |
Unsplit |
| Geom |
quick edit |
washer split |
Split/Lines + Offset |
| Geom |
replace node |
Edit Elements/Replace |
| Geom |
ribs |
Ribs |
| Geom |
solid edit |
boolean |
Boolean |
| Geom |
solid edit |
detach |
Boolean/Detach |
| Geom |
solid edit |
merge |
Boolean |
| Geom |
solid edit |
trim with lines |
Split/Lines |
| Geom |
solid edit |
trim with nodes |
Split/Planes |
| Geom |
solid edit |
trim with plane/surf |
Split/Planes |
| Geom |
solids |
block |
Solids/Box |
| Geom |
solids |
bounding surfaces |
Solids/Bounding Surfaces |
| Geom |
solids |
cone full |
Deprecated |
| Geom |
solids |
cone partial |
Deprecated |
| Geom |
solids |
cylinder full |
Solids/Cylinder |
| Geom |
solids |
cylinder partial |
Solids/Cylinder + Split |
| Geom |
solids |
drag along vector |
Extrude |
| Geom |
solids |
drag along normal |
Extrude |
| Geom |
solids |
drag along line |
Extrude |
| Geom |
solids |
ruled linear |
Ruled/Linear |
| Geom |
solids |
ruled smooth |
Ruled/Smooth |
| Geom |
solids |
sphere center and radius |
Solids/Sphere |
| Geom |
solids |
sphere four nodes |
Solids/Sphere |
| Geom |
solids |
spin |
Revolve |
| Geom |
solids |
torus center and radius |
Deprecated |
| Geom |
solids |
torus partial |
Deprecated |
| Geom |
solids |
torus three nodes |
Deprecated |
| Geom |
surface edit |
extend |
Surfaces/Extend |
| Geom |
surface edit |
offset |
Offset |
| Geom |
surface edit |
shrink |
Split/Lines + Offset + Delete |
| Geom |
surface edit |
trim with lies |
Split/Lines |
| Geom |
surface edit |
trim with nodes |
Split/Nodes |
| Geom |
surface edit |
trim with surfs/plane |
Split/Planes |
| Geom |
surface edit |
untrim |
Unsplit |
| Geom |
surfaces |
cone full |
Deprecated |
| Geom |
surfaces |
cone partial |
Deprecated |
| Geom |
surfaces |
cylinder full |
Solids/Cylinder |
| Geom |
surfaces |
cylinder partial |
| Geom |
surfaces |
drag along line |
Extrude |
| Geom |
surfaces |
drag along normal |
Extrude |
| Geom |
surfaces |
drag along normal from surfaces |
Extrude |
| Geom |
surfaces |
drag along vector |
Extrude |
| Geom |
surfaces |
fillet |
Fillets |
| Geom |
surfaces |
from fe |
Surfaces/From FE |
| Geom |
surfaces |
meshline |
Deprecated |
| Geom |
surfaces |
ruled |
Surfaces/Patch |
| Geom |
surfaces |
skin |
Surfaces/Skin |
| Geom |
surfaces |
Solids/Sphere |
| Geom |
surfaces |
sphere four nodes |
Solids/Sphere |
| Geom |
surfaces |
sphere partial |
Deprecated |
| Geom |
surfaces |
spin |
Revolve |
| Geom |
surfaces |
spline/filler |
Surfaces/Patch |
| Geom |
surfaces |
square |
Rectangle |
| Geom |
surfaces |
Deprecated |
| Geom |
surfaces |
torus partial |
Deprecated |
| Geom |
surfaces |
torus three nodes |
Deprecated |
| Geom |
temp nodes |
Nodes/Create Free Nodes; Nodes/Mark Free Nodes; Browser/Entity Editor
| HyperForm |
addendum |
Deprecated |
| HyperForm |
advanced |
User Process browser |
| HyperForm |
autotipping |
| HyperForm |
binder |
Deprecated |
| HyperForm |
blank shape |
| HyperForm |
blankholder |
| HyperForm |
circle grid |
Deprecated |
| HyperForm |
components |
User Process browser; Assembly Ribbon |
| HyperForm |
constraints |
Tools pull-down menu |
| HyperForm |
contacts |
| HyperForm |
curves |
Model Browser Curve |
| HyperForm |
dieinit |
Deprecated |
| HyperForm |
doubleattach |
Deprecated |
| HyperForm |
drawbeads |
| HyperForm |
editautobind |
Deprecated |
| HyperForm |
editbinder |
Deprecated |
| HyperForm |
fld curve |
| HyperForm |
fld plots |
| HyperForm |
geom cleanup |
Geometry ribbon |
| HyperForm |
line design |
Deprecated |
| HyperForm |
line mapping |
Deprecated/Inspire Form |
| HyperForm |
load results |
| HyperForm |
materials |
| HyperForm |
materials1 |
| HyperForm |
modify addendum |
Deprecated |
| HyperForm |
part outline |
| HyperForm |
prep geom |
Deprecated |
| HyperForm |
run analysis |
| HyperForm |
section edit |
Deprecated |
| HyperForm |
sections |
| HyperForm |
tool build |
| HyperForm |
tool loads |
| HyperForm |
tool motion |
| HyperForm |
undercut chk |
| HyperMorph |
domains |
create |
Morph
Domains |
| HyperMorph |
domains |
edit edges |
Morph
Domains |
| HyperMorph |
domains |
organize |
Morph
Domains |
| HyperMorph |
domains |
parameters |
Morph
Domains |
| HyperMorph |
domains |
partitioning |
Morph
Domains |
| HyperMorph |
domains |
update |
Morph
Domains |
| HyperMorph |
freehand |
move nodes |
Morph/Free |
| HyperMorph |
freehand |
record |
Morph/Shapes - Record |
| HyperMorph |
freehand |
save shape |
Morph/Shapes |
| HyperMorph |
freehand |
sculpting |
Morph/Free |
| HyperMorph |
handles |
create |
Morph
Handles |
| HyperMorph |
handles |
load |
Morph
Handles |
| HyperMorph |
handles |
save |
Morph
Handles |
| HyperMorph |
handles |
update |
Morph
Handles |
| HyperMorph |
map to geom |
Map to Geometry |
| HyperMorph |
morph |
alter dimensions |
Morph Alter Dimensions |
| HyperMorph |
morph |
apply shapes |
Morph/Shapes |
| HyperMorph |
morph |
morph surfaces |
Deprecated |
| HyperMorph |
morph |
move handles |
Morph/Free |
| HyperMorph |
morph |
save shape |
Morph/Shapes |
| HyperMorph |
morph |
set biasing |
Morph
Set Bias |
| HyperMorph |
morph |
set constraints |
Morph/Constraints |
| HyperMorph |
morph constraints |
create/update |
Morph/Constraints |
| HyperMorph |
morph constraints |
release nodes |
Morph/Constraints |
| HyperMorph |
morph options |
auto qa |
Preferences |
| HyperMorph |
morph options |
domain solvers |
Preferences |
| HyperMorph |
morph options |
fea results |
Preferences |
| HyperMorph |
morph options |
global |
Preferences |
| HyperMorph |
morph options |
morphing |
Preferences |
| HyperMorph |
morph options |
parameters |
Preferences |
| HyperMorph |
morph volumes |
convert |
Morph Volumes |
| HyperMorph |
morph volumes |
create |
Morph Volumes |
| HyperMorph |
morph volumes |
parameters |
Morph Volumes |
| HyperMorph |
morph volumes |
save/load |
Morph Volumes |
| HyperMorph |
morph volumes |
split/combine |
Morph Volumes |
| HyperMorph |
morph volumes |
update edges |
Morph Volumes |
| HyperMorph |
morph volumes |
update mvols |
Morph Volumes |
| HyperMorph |
shapes |
animate shapes |
Morph/Shapes |
| HyperMorph |
shapes |
apply shapes |
Mirror; Scale; Move |
| HyperMorph |
shapes |
save as shape |
Morph/Shapes |
| HyperMorph |
shapes |
save/load |
Morph/Shapes |
| HyperMorph |
symmetry |
create |
Morph
Symmetries |
| HyperMorph |
symmetry |
update by domain |
Morph
Symmetries |
| Optimization |
composite shuffle |
create |
| Optimization |
composite shuffle |
parameters |
| Optimization |
composite shuffle |
update |
| Optimization |
composite size |
create |
| Optimization |
composite size |
parameters |
| Optimization |
composite size |
update |
| Optimization |
constr screen |
| Optimization |
dconstraints |
| Optimization |
dequations |
| Optimization |
desvar link |
dlink |
| Optimization |
desvar link |
dlink2 |
| Optimization |
discrete dvs |
| Optimization |
free shape |
create |
| Optimization |
free shape |
draw/extr |
| Optimization |
free shape |
gridcon |
| Optimization |
free shape |
parameters |
| Optimization |
free shape |
pattern grouping |
| Optimization |
free shape |
sidecon |
| Optimization |
free shape |
update |
| Optimization |
free size |
composites |
| Optimization |
free size |
create |
| Optimization |
free size |
parameters |
| Optimization |
free size |
pattern grouping |
| Optimization |
free size |
pattern repetition |
| Optimization |
free size |
update |
| Optimization |
free size |
zone based |
| Optimization |
gauge |
create |
| Optimization |
gauge |
review |
| Optimization |
gauge |
update |
| Optimization |
lattice params |
| Optimization |
obj reference |
| Optimization |
objective |
| Optimization |
opti control |
| Optimization |
perturbations |
domain/create |
Morph/Shapes |
| Optimization |
perturbations |
domain/update |
Morph/Shapes |
| Optimization |
perturbations |
perturbations/create |
Morph Shapes |
| Optimization |
perturbations |
perturbations/update |
Morph/Shapes |
| Optimization |
responses |
| Optimization |
shape |
desvar/create |
Morph/Shapes |
| Optimization |
shape |
desvar/update |
Morph/Shapes |
| Optimization |
shape |
export |
Morph/Shapes |
| Optimization |
size(parameter) |
desvar |
| Optimization |
size(parameter) |
function relationship |
| Optimization |
size(parameter) |
generic relationship |
| Optimization |
table entries |
| Optimization |
topography |
bead params |
| Optimization |
topography |
bounds |
| Optimization |
topography |
create |
| Optimization |
topography |
pattern grouping |
| Optimization |
topography |
| Optimization |
topography |
update |
| Optimization |
topology |
create |
| Optimization |
topology |
draw |
| Optimization |
topology |
extrusion |
| Optimization |
topology |
parameters |
| Optimization |
topology |
pattern grouping |
| Optimization |
topology |
| Optimization |
topology |
update |
| Post |
apply result |
create loads |
Fields |
| Post |
apply result |
displacements |
Fields; Morph |
| Post |
contour |
HM
Post |
| Post |
deformed |
HM Post |
| Post |
fatigue |
HyperLife |
| Post |
hidden line |
Section
Cut |
| Post |
ossmooth |
OSSmooth |
| Post |
summary |
Measure |
| Post |
titles |
Support in DB but not in UI, eventually replace with
annotations |
| Post |
transient |
HM Post |
| Post |
vector plot |
HM Post |
| Safety |
0-D elems |
| Safety |
create joints |
card image |
Deprecated |
| Safety |
create joints |
create |
Deprecated |
| Safety |
create joints |
update |
Deprecated |
| Safety |
dummy |
H-point |
Deprecated |
| Safety |
dummy |
incremental |
Deprecated |
| Safety |
ellipsoids |
create |
Deprecated |
| Safety |
ellipsoids |
update |
Deprecated |
| Safety |
fe joints |
create |
Joints |
| Safety |
fe joints |
update |
| Safety |
files |
command |
File
Menu |
| Safety |
files |
export |
File
Menu |
| Safety |
files |
hm file |
File
Menu |
| Safety |
files |
import |
File
Menu |
| Safety |
files |
results |
File
Menu |
| Safety |
files |
template |
File
Menu |
| Safety |
joint dof |
H-point |
Deprecated |
| Safety |
joint dof |
incremental |
Deprecated |
| Safety |
MBS joints |
card image |
Deprecated |
| Safety |
MBS joints |
create |
Deprecated |
| Safety |
MBS joints |
update |
Deprecated |
| Safety |
multibody collectors |
create |
Deprecated |
| Safety |
update |
Deprecated |
| Safety |
planes |
create |
Deprecated |
| Safety |
planes |
permute |
Deprecated |
| Safety |
planes |
resize |
Deprecated |
| Safety |
planes |
update |
Deprecated |
| Safety |
sensors |
| Safety |
set joints |
H-point |
Deprecated |
| Safety |
set joints |
incremental |
Deprecated |
| Tool |
assemblies |
card image |
| Tool |
assemblies |
create |
| Tool |
beam section collectors |
create |
| Tool |
update |
| Tool |
build menu |
Deprecated |
| Tool |
card edit |
Card Editor |
| Tool |
check elems |
1-d |
Element Quality Legend; Model
Checker |
| Tool |
check elems |
2-d |
Checker |
| Tool |
check elems |
3-d |
Checker |
| Tool |
check elems |
group |
Browser; Model Checker |
| Tool |
check elems |
time |
Checker |
| Tool |
check elems |
user |
Deprecated |
| Tool |
color |
| Tool |
components |
assign |
Property Assign |
| Tool |
components |
create |
| Tool |
components |
update |
| Tool |
count |
BC entities |
| Tool |
count |
FE entities |
| Tool |
count |
geometry |
| Tool |
count |
morph |
| Tool |
count |
optimization |
| Tool |
count |
safety |
Browser |
| Tool |
delete |
| Tool |
dependency |
Model
Checker |
| Tool |
edges |
Edges; Equivalence |
| Tool |
faces |
Faces; Equivalence |
| Tool |
features |
edit |
Feature Edges/Edit |
| Tool |
features |
features |
Feature Edges/Create |
| Tool |
find |
between |
Find |
| Tool |
find |
find attached |
Find |
| Tool |
find |
find entities |
Find |
| Tool |
load collectors |
create |
| Tool |
load collectors |
update |
| Tool |
mask |
mask |
Idle; Show/Hide |
| Tool |
mask |
unmask |
Idle; Show/Hide |
| Tool |
mass calc |
elements |
Calculate |
| Tool |
mass calc |
solids |
Calculate |
| Tool |
mass calc |
surfaces |
Calculate |
| Tool |
materials |
create |
| Tool |
materials |
update |
| Tool |
normals |
elements |
Normals |
| Tool |
normals |
surfs |
Normals |
| Tool |
numbers |
Renumber; Idle |
| Tool |
organize |
collectors |
Organize |
| Tool |
organize |
includes |
Organize |
| Tool |
organize |
parts |
Organize |
| Tool |
penetration |
Penetration |
| Tool |
permute |
Deprecated |
| Tool |
position |
Move > Position |
| Tool |
project |
to line |
Align/Lines |
| Tool |
project |
to plane |
Align/Plane |
| Tool |
project |
to surface |
Align/Surfaces |
| Tool |
project |
to vector |
Align/Plane |
| Tool |
properties |
assign |
Property Assign |
| Tool |
properties |
create |
| Tool |
properties |
update |
| Tool |
reflect |
Mirror |
| Tool |
rename |
all by id |
Browser |
| Tool |
rename |
individually |
| Tool |
renumber |
single |
Renumber |
| Tool |
renumber |
all |
Renumber |
| Tool |
reorder |
Reorder |
| Tool |
rotate |
Move; Transformation tool |
| Tool |
scale |
Scale |
| Tool |
system collectors |
create |
| Tool |
system collectors |
update |
| Tool |
tags |
create |
Tags |
| Tool |
tags |
update |
| Tool |
translate |
| Tool |
vector collectors |
create |
| Tool |
vector collectors |
update |
| XY Plots |
axis labels |
Curve
Editor |
| XY Plots |
axis scaling |
Curve
Editor |
| XY Plots |
border |
Curve
Editor |
| XY Plots |
curve attribs |
Curve
Editor |
| XY Plots |
edit curves |
create |
Curve
Editor |
| XY Plots |
edit curves |
modify |
Curve
Editor |
| XY Plots |
grid attribs |
Curve
Editor |
| XY Plots |
grid labels |
Curve
Editor |
| XY Plots |
integrate |
Curve
Editor |
| XY Plots |
legend |
Curve
Editor |
| XY Plots |
plot titles |
Curve
Editor |
| XY Plots |
plots |
Curve
Editor |
| XY Plots |
query curves |
Curve
Editor |
| XY Plots |
read curves |
along nodes |
Curve
Editor |
| XY Plots |
read curves |
position |
Curve
Editor |
| XY Plots |
read curves |
results |
Curve
Editor |
| XY Plots |
simple math |
Curve
Editor |
