Browsers provide a structured view of model data, which you can use to review, modify, create, and manage
the contents of a model. In addition to visualization, browsers offer features like search, filtering, and sorting,
which enhance your ability to navigate and interact with the model data.
FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
Tools and workflows that are dedicated to rapidly creating new parts for specific use cases, or amending existing
parts. The current capabilities are focused on stiffening parts.
Use PhysicsAI to build fast predictive models from CAE data. PhysicsAI can be trained on data with any physics or
remeshing and without design variables.
Explore, organize and manage your personal data, collaborate in teams, and connect to other data sources, such as
corporate PLM systems to access CAD data or publish simulation data.
Introduction to Sketching
Learn about sketching basics including the sketch plane, legend, constraints, context menu options, and construction geometry.
Variables
Create and assign variables to parameters when modeling.
New Sketch
Start a new sketch and select a sketch plane.
Project
Project selected geometry onto the sketch plane as construction geometry.
Intersect
Extract curves resulting from the intersection of the sketch plane with selected parts.
Point/Lines
Sketch and edit a point, line, polyline, or line-arc.
