Browsers provide a structured view of model data, which you can use to review, modify, create, and manage
the contents of a model. In addition to visualization, browsers offer features like search, filtering, and sorting,
which enhance your ability to navigate and interact with the model data.
FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
Manage all of the IDs for the entities that you create, and define ID ranges for all of the entities in each Include
file in relation to the full model in order to avoid ID duplication.
Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
Local coordinate systems can be used for setting up loads/boundary conditions that do not act in the global axis direction,
transforming results, defining material orientation, and many other operations.
Use the Auto Contacts tool to determine contact interfaces between selections of components or elements. Based on
the user-specified options like proximity tolerance, surface creation method, main surface type, and secondary type,
the tool generates contacts based on set segments or node and element combinations.
Tools and workflows that are dedicated to rapidly creating new parts for specific use cases, or amending existing
parts. The current capabilities are focused on stiffening parts.
Use PhysicsAI to build fast predictive models from CAE data. PhysicsAI can be trained on data with any physics or
remeshing and without design variables.
Explore, organize and manage your personal data, collaborate in teams, and connect to other data sources, such as
corporate PLM systems to access CAD data or publish simulation data.
PostgreSQL Installation and Configuration
Also referred to as Postgres, PostgreSQL is an object-relational database management system with emphasis on extensibility and standards compliance.
Section Library
Use the automotive section library for rapid concept development in the early phases of the vehicle design process.
Organize Entities
Use the Organize tool to move or copy entities into their proper destinations.
Match Parts
Automatically group selected parts into part sets based on comparison method and criteria selected.
Classify Parts
Set up and use machine learning (ML) models to automatically classify parts under user-defined labels and into part sets.
Renumber Entities
Use the Renumber tool to review and organize the IDs of model entities.
Reorder Entities
Change the order of named entities in database.
ID-Management
Manage all of the IDs for the entities that you create, and define ID ranges for all of the entities in each Include file in relation to the full model in order to avoid ID duplication.
Manage Scenarios
Scenarios are a mechanism to apply controls to engineering entities.
Mechanism Browser
Create and articulate a kinematic mechanism based on FE mesh using the Mechanism Browser.
Model Verification
Systems
Local coordinate systems can be used for setting up loads/boundary conditions that do not act in the global axis direction, transforming results, defining material orientation, and many other operations.
Generate Contacts Automatically
Use the Auto Contacts tool to determine contact interfaces between selections of components or elements. Based on the user-specified options like proximity tolerance, surface creation method, main surface type, and secondary type, the tool generates contacts based on set segments or node and element combinations.
