Use the Query tool to measure areas, volumes, entity counts, line lengths, bounding
boxes, and more.
This tool can be utilized to identify where meshing failed
or the solver created "bc warnings".
Click the arrow next to the Home tool set, then
select Query.
Select entities to measure in the modeling window.
The supported entity types are: parts, solids, surfaces, lines, points, and
nodes.
Based on the entity type, the available measurement information may
change.
- Optional:
Click
in the microdialog to
toggle bounding box visualization.
Click Compute to generate measurements for you
selection.
Tip: You can copy printed information from the
text box and use it for any other dialog.
