MotionView Python Reference Guide
Introduction
Starting in v2021, a Python API is available for MotionView.
Through the python API, it is possible to:
  • Customize MotionView
  • Automate repetitive tasks through python scripts
  • Integrate MotionView with other external tools that have a python interface
Why Python?
Python is:
  • Easy to learn and use.
  • Popular among developers with over 250 thousand open source projects in https://pypi.org.
  • Popular in the scientific community, as it is well suited for numerical calculations.
  • Free - there are many publicly available web sites and resources dedicated to teaching Python.
  • Robust - it can also scale to solve complex problems.
  • Flexible - it is extremely well suited for rapid development and prototyping.
MotionView Python Class
The API is provided in a set of classes which represent different MotionView entities.
Properties
Every class has a list of properties which can be set during its instantiation or can be modified after its creation.
Along with the properties, each entity also has functions which can be called on a specific entity.
Properties define the user input values of a MotionView entity, for example:
  • The mass of a Body
  • The CM (center of mass marker) of a Body
  • The friction property of a Joint
The properties can be classified into three categories:
Property Type Description Examples
Keyword Arguments Modifiable data x, y, or z property of a Point class
mass property of a Body class
Instances Instance of another entity cm property of a Body class is an Instance of a Marker class
friction class within a Joint class
Readonly Properties Unmodifiable data ID property of any entity class
Data Types
The MotionView Python API supports the following data types:
Data Type Description
Int Python integer value.
Bool Python bool value.
Double Python float value.
String Python string value.
Enum Python string value that must be one of a specified list of values applicable for an entity attribute.
For example, a type property of a SpringDamper entity can only be one of TorsionSpring or CoilSpring.
Reference Reference to an existing MotionView entity.
For example, Body-cg refers to a Point entity.
Dict Python dict.
File Python string which contains a legal file path.
NumericVector Python list of Doubles.
StringVector Python list of **String** values.
Function Python string which contains a legal solver function enclosed in \`\`.
注: The values assigned to properties should be compatible with a corresponding MotionView property data type.
