A preference file is an ASCII file that configures the application or its clients. It specifies default user settings, such as the order in which
colors are assigned, the default printer and default page layout.
Extensions
hm.cfg HyperMesh has a configuration file named hm.cfg, which is read on startup and is located in the <install_directory>/hw/bin/<platform> directory.
Preference Files
A preference file is an ASCII file that configures the application or its clients. It specifies default user settings, such as the order in which colors are assigned, the default printer and default page layout.
Session Files
A session file is an ASCII text file that contains a structured list of session statements.
Report Templates
Report templates are ASCII text files that contain statements for creating reports.
