Test Models
Use the Model Testing tools to test models and review test results.
From the PhysicsAI ribbon, select the Test
Machine Learning Model tool.
図 1.The Test Model dialog opens. -
Select a model and Dataset.
図 2. -
Click OK.
The Model Testing dialog opens.ヒント: You can also open the Model Testing dialog by selecting the Review Test Results tool.
図 3. - Click Detailed Report to open the View Score Report.
- In the Model Testing dialog, select a Run ID and click Show Results to view the results in the モデリングウィンドウ.
- Close the Model Testing dialog.
