Identify one or more outlet surfaces and define the conditions.
On the Fluids ribbon, select the Outlet tool.
![](../../images/icons/cfd/icon_cfd_outlet.png)
Select one or more surfaces as the outlets.
In the microdialog, define the pressure.
Tip: The pressure is defined relative to the
atmospheric pressure. To set the outlet pressure equal to the atmospheric
pressure, enter 0.
