Part
Define the constant heat source for the thermal power generated by the solid part.
On the Fluids ribbon, select the Part tool.
- Select one or more solid parts.
In the microdialog, define the Heat source:
- Per Unit Volume
- Per Unit Mass
- Total Power
- Based on the unit you selected, follow the relevant steps below.
Per Unit Volume
Specify the constant heat source by the thermal power per unit volume.
Per Unit Mass
Specify the constant heat source by the thermal power per unit mass.
Total Power
Specify the constant heat source by the total thermal power.
