Altair® Panopticon™
Adding a New Data Table in the Data Library
You can add data tables that can be joined or imported to data stores in the Data Library page. These data tables will also be available in the Add and Edit Data Table Wizards that are available in a workbook.
1.      Create a new data table by doing one of the following:
·        Click   on the Data Library page, or
·        Right-click on a folder or subfolder then select New Data Table in the context menu.
The New Data Table dialog displays.
2.      Enter the name of the data table then click .
The data source groups you can select are displayed.
3.      Click the data source group tab.
·        File/URL
Then select one of these data sources:
·        Altair AI Hub
·        Altair IoT Studio
·        Altair IoT Studio Write
·        Azure
·        Google Cloud
·        JSON
·        MS Excel
·        OneDrive
·        S3
·        SVG
·        Text
·        Web Data
·        XML
·        Database
·        Cassandra
·        DolphinDB
·        Elasticsearch 6.x
·        Elasticsearch 7.x
·        Google Analytics
·        InfluxDB
·        JDBC Legacy
·        JDBC
·        Kx kdb+
·        KsqlDB
·        LivySpark
·        MongoDB
·        OneTick
·        OneTick Cloud
·        Panopticon Data Extract
·        Python
·        Rserve
·        Shakti Beta
·        Splunk
·        Streaming
·        ActiveMQ
·        Amazon Kinesis – Data Streams
·        AMPS
·        DolphinDB - Streaming
·        Google Cloud Pub/Sub
·        JDBC Database - Streaming
·        Kafka
·        Kafka Publisher
·        Kdb+ Tick
·        KsqlDB – Streaming
·        MQTT
·        OneTick CEP
·        Panopticon Streams
·        RabbitMQ
·        Redis Streams
·        Solace
·        Streams Simulator
·        Streams Simulator - Extract
·        StreamBase 7.1
·        StreamBase LiveView
·        WebSocket
The Data Table Editor displays. The example below displays the connector settings for the MS Excel data source.
See Working with the Data Table Editor for more information.
