Define Mesh Controls
Use the Mesh dialog to define mesh settings.
From the Setup ribbon, click the
Advanced meshing parameters tool.
Figure 1.The Mesh dialog opens. -
In the Mesh dialog, define the desired mesh controls settings.
- Triangle plinth
- Create a plinth surface around single voxel gaps near the wind tunnel ground.
- Triangle splitting
- Activate triangle splitting of surfaces.
- If Triangle splitting is enabled, the following edge length controls apply:
- Maximum relative edge length
- Triangle edge length relative to the local voxel size.
- Maximum absolute edge length
- Maximum triangle edge length.
- Far field element size
- Coarsest element size.
- Refinement level transition layers
- Minimum number of elements to create between mesh refinement zones.
- Click Close.
