HMIN_writeattribute_double_array()
Transfers a double array attribute to HyperMesh.
void HMIN_writeattribute_double_array(HM_entitytype entitytype, HM_entityidtype id, int identifier, int behavior, int status, const double value[], int length);
HyperMesh hminlib Function
- entitytype
- The type of the entity to which to attach the attribute.
- id
- The ID of the entity to which to attach the attribute.
- identifier
- The attribute identifier (defined in a template with the *defineattribute() command).
- behavior
- Set to 0, reserved for future use.
- status
- Set to 0 for off.
- value
- The values to be assigned to the attribute.
- length
- The length of the array.
None.
