HMIN_line_write()
Writes a line to HyperMesh.
void HMIN_line_write(HM_entityidtype id, double geometric[3][4], HM_entityidtype componentid);
HyperMesh hminlib Function
id
The ID of the line.
geometric[3][4]
The geometric coordinates of the line. The number in the first set of brackets indicates which coordinate is given. Assign:
  • 0 - For the x coordinate.
  • 1 - For the y coordinate.
  • 2 - For the z coordinate.
The number in the second set of brackets indicates which point the given coordinate is. Assign:
  • 0 - For the starting point.
  • 1 - For the ending point.
  • 2 - For the start tangent.
  • 3 - For the end tangent.
componentid
The ID of the component.
None.
