HMIN_transform_nodetoglobal()
Allows nodes to be transformed to a global coordinate system, based on the local coordinate system.
void HMIN_transform_nodetoglobal(double input[3], int type, double origin[3], double axis[3][3], double output[3]);
HyperMesh hminlib Function
- input[3]
- The coordinates of the node.
- type
- The type of coordinate system.
- origin[3]
- The origin of the coordinate system.
- axis[3][3]
- The axes of the coordinate system.
- output[3]
- The output of the coordinate system.
None.
