hm_clearmarker
Clears the graphical marker created by hm_plotmarker.
hm_clearmarker ?entity_type? ?<select_type>=<selection>? ?dataname=<data name/attribute>?
HyperMesh Tcl GUI Command
To clear specific markers on specific entities: hm_plotmarker entity_type <select_type>=<selection> dataname=<data name/attribute>
To clear all markers on specific entities: hm_plotmarker entity_type <select_type>=<selection>
To clear all markers on a specific entity type: hm_plotmarker entity_type
To clear all markers: hm_plotmarker
- entity_type
- The type of entity to clear markers for. Valid values are nodes, elements, points, lines, surfs and solids.
- <select_type>=<selection>
- The entity or entities to clear markers for.
- dataname=<data name/attribute>
- The data name or attribute to clear markers for.
Examples
*createmark elems 1 1-100
hm_clearmarker elements mark=1 dataname=id*createmark elems 1 1-100
hm_clearmarker elements mark=1hm_clearmarker elementshm_clearmarkerErrors
# Handle error
}Version History
2019.1
