hm_plotentity
Plots entity as either a vector or a contour plot.
hm_plotentity hm_plotentity entity_type mark_id dataname=<value> plottype=<value>
HyperMesh Tcl GUI Command
entity_type
The type of entity to plot. Currently only supported for constraints.
mark_id
The ID of the mark containing the entities to plot. Valid values are 1 and 2.
dataname=<value>
The data name which is to be extracted and plotted.
plottype=<value>
0 - Clear plot
1 – Vector plot (not valid for constraints)
2 – Interactive contour plot
3 – Static scalar plot
Examples
To create a contour plot of data name weights for all constraints:
*createmark constraints 1 all
        hm_plotentity constraints 1 dataname=weights plottype=2
   # Handle error
Version History
2022
