hm_getstring
Get a string value using a dialog.
hm_getstring ?label? ?title? ?default_value?
HyperMesh Tcl GUI Command
This command returns a string value by providing the user with a dialog.
?label?
The entry label. Default is “Value =”.
?title?
The dialog title. Default is “Enter a string…”. label must be specified to use this option.
?default_value?
Optional default string in the entry field. title must be specified to use this option.
set label1 [hm_getstring "Label=" "Please specify the label"]
None.
Version History
2017.1 - Added new optional default_value argument.
