hm_getfilename
Get a filename using an open file dialog.
hm_getfilename ?message? ?default_value?
HyperMesh Tcl GUI Command
This command returns a file name by providing you with an open file dialog.
?message?
Optional string to show in the status bar when entering the panel.
?default_value?
Optional default string to set when entering the panel. message must be specified to use this option.
set fname [hm_getfilename "Please select a file"]
None.
Version History
2017.1 - Added new optional default_value argument.
