hm_getint
Get an integer value using a dialog.
hm_getint ?label? ?title? ?default_value?
HyperMesh Tcl GUI Command
This command returns an integer value by providing you with a dialog.
?label?
The entry label. Default is “Value =”.
?title?
The dialog title. Default is “Enter an integer value…”. label must be specified to use this option.
?default_value?
Optional default integer value in the entry field. title must be specified to use this option.
set count [hm_getint "Count=" "Please specify the count"]
None.
Version History
2017.1 - Added new optional default_value argument.
