hm_highlightmark
Control the highlighting of a mark of entities.
hm_highlightmark entity_type mark_id highlight
HyperMesh Tcl GUI Command
- entity_type
- The type of entity to control the highlighting for.
- mark_id
- The ID of the entity mark. Valid values are 1 and 2.
- highlight
- The state of the highlighting. Valid values are:
- l, low or lowlight - set to low (gray) highlighting
- n, norm or normal - set to normal (no) highlighting
- h, high or highlight - set to high (white) highlighting
To display a mark of elements in a low state:
*createmarkpanel elems 1 "Select the elements"
hm_highlightmark elems 1 "low"
# Handle error
}Version History
2023 - Deprecated argument panel_sensitive.
