hm_getscreenvector
Returns either the normal or parallel screen vector.
hm_getscreenvector vector
HyperMesh Tcl Query Command
Returns either the normal or parallel screen vector. The output is the same vector direction you get when using hm_getdirectionpanel and selecting "screen normal" or "screen parallel".
- vector
- normal - The normal screen vector.
Examples
To get the parallel screen vector:
hm_getscreenvector parallel
# Handle error
}Version History
2019
