hm_wm
Provides a limited interface to the HyperMesh window.
hm_wm option ?value?
HyperMesh Tcl GUI Command
This command returns the value of certain HyperMesh window settings. It can also set the window title string.
- option ?value?
- The option to query/set. Valid values are:
- graphicfont - Returns the font used for the modeling window.
- title - Returns the current window title string.
- title value - Sets the current window title string to value.
To change the current window title:
set curTitle [hm_wm title]
hm_wm title "$curTitle - My HyperMesh"
None.
Version History
2023 - Removed options menufont and pulldowns.
