HMIN_blocksimple_write()
Writes a block to HyperMesh for use with interfaces and loadsteps (instead of finite difference blocks).
void HMIN_blocksimple_write(HM_entityidtype id, char * name, int color, double minimum[3], double maximum[3]);
HyperMesh hminlib Function
- id
- The ID of the block to be written.
- name
- The name of the block.
- color
- The color of the block.
- minimum[3]
- The minimum values of the x, y, and z coordinates in the block.
- maximum[3]
- The maximum values of the x, y, and z coordinates in the block.
Use this function to transfer any blocks to HyperMesh that are simple enough not to contain any divisions, cells, or walls.
None.
