HMIN_dvprel_write()
Writes a design variable property (dvprel) to HyperMesh.
void HMIN_dvprel_write(HM_entityidtype id,char *name,int property,HM_entityidtype propertyid,int fieldposition,unsigned int ishear,double pmin,double pmax,double c0, HM_entityidtype functionid,int desvarlistmax,HM_entityidtype *desvarlist, int tableentrylistmax,HM_entityidtype *tableentrylist,double *coeff);
HyperMesh hminlib Function
- id
- The id of the dvprel.
- name
- The name of the dvprel.
- property
- The possible values for property are listed below:
Property Value Property Type 1 PSHELL 5 PBAR 6 PBEAM 7 PELAS 8 PROD 14 CONM2 - propertyid
- The id of the property.
- fieldposition
- Field position of the property. A detailed explanation of this field can be found in the OptiStruct online help.
- ishear
- Currently unused.
- pmin
- Minimum value allowed for the property.
- pmax
- Maximum value allowed for the property.
- c0
- Constant in relationship equation.
- functionid
- Equation id of DEQATN data (for DVPREL2 card).
- desvarlistmax
- The number of design variables referenced by the dvprel.
- desvarlist
- An array containing the ids of the design variables.
- tableentrylistmax
- The number of DTABLE entries referenced by the dvprel.
- tableentrylist
- An array containing the ids of the table entries.
- coeff
- An array containing the coefficients associated with each of the design variables.
None.
